Old 6th September 2010, 08:09 PM
shh120m's Avatar
shh120m shh120m is offline
Default front frame
hi guys
Does anyone supply the front frame ready made? as im struggling with time at the mo and i really want to get on with the chassis
thanks
nathan
Old 6th September 2010, 08:14 PM
David_17's Avatar
David_17 David_17 is offline
Yep, Saturn at hartlepool.
http://www.saturnsportscars.co.uk/st...d&productId=48
*updated 7/6/11*
Old 6th September 2010, 08:42 PM
shh120m's Avatar
nice one!
Old 11th September 2010, 02:16 PM
shh120m's Avatar
well, i had a look at my huge steel stock and thought i may as well have a go at the front frame, at worst i would waste a bit of tube. After almost severing my finger with a hacksaw and cocking up the section cut i finally managed it and its straight!!!!
il get some pics up later
Should i Fully weld the front frame to the bottom chassis rails at this stage or just tack them and leave some claps in place? im trying to keep my tacks as small as possible so i can get some beautiful welds later on without having to do too much grinding.
Old 11th September 2010, 02:31 PM
Congratulations on getting the front frame done, I had a nightmare with mine during the week, I am sure it is born of the devil, a son of Satan
Old 11th September 2010, 07:21 PM
shh120m's Avatar
image as promised
Yep, it really is evil!
i really hope thats the hardest bit.....
Old 11th September 2010, 07:26 PM
well done at cracking the front frame,
Yes it is the hardest bit in the chassis build
May I ask which gearbox you are fitting? if its the Type 9 box then you have part "U7" in the wrong place , said politely .
Old 11th September 2010, 08:01 PM
shh120m's Avatar
Oops,
I completely overlooked that. I was intending on using an mt75. Will it be ok to leave it in position or does tr5 have to butt up to it?
Old 11th September 2010, 08:07 PM
If you are using the MT75 box, then check the info in the announcement section which gives the dimensions of the chassis when installing a MT75 box,
As for TR5..... it all depends on which engine you are using, the "Book" has been written around installing a Pinto engine, so TR5 fits no prob, but if installing any other engine TR5 tends to get in the way,
some builders don,t install TR5 at all & put extra corner braces between TR1 to TR8 & TR2 to TR8.
hope this helps.
Old 11th September 2010, 08:14 PM
shh120m's Avatar
great, thanks
I might do away with tr5 then,as im undecided on the engine just yet as i need to get the chassis rolling first due to space issues. Iv just bought a mini milling machine so il try and make some sexy looking corner braces.
nathan
