Old 10th September 2010, 09:14 PM
Default Some progress at last
Hi, have spent the afternoon in the garage and managed to get the bottom frame tacked together. Boy oh boy, do I hate the from frame. About two weeks ago I built a jig for the assembly of the front frame. I spent ages on Wednesday enening cutting all the angles and checking each and every angle and length three times over. I placed them all into the jig and proceeded to tack it all together, removed it from the jig to find nothing was right. The 75mm off set was 83mm and nothing was right. I eventually found that the base board had warped and this was throwing everything out, so I took it all apart and re-did it all without the jig and it came out right happy days. I have up loaded some photos and hopefully this link will give some idea of progress made.
http://s900.photobucket.com/albums/a...f/haynesbuild/
Old 10th September 2010, 09:28 PM
Nice work Arfon,
The front frame can be a little blighter , so well done on keeping at it
I look forward to seeing more pics of your build
Keep an eye on the position of U7
Old 10th September 2010, 09:35 PM
Thanks Andy, I think it can be said that the front frame could be the son of Satan, and the cause of many cases of insanity
Old 10th September 2010, 09:40 PM
It gets easier the more you make
But, yes, my very first attempt at the front frame ended up flying across the garage so you are not alone , now takes me about 15 mins from start to finish
Like your workshop too
Old 10th September 2010, 09:51 PM
Wish I could do it in 15mins, as for the workshop I am very lucky as I have a great mother-in-law whos' garage it is and as she doesn't drive she has given me free-rain to have it as I want it
Old 10th September 2010, 09:57 PM
I have a great mother in law too.......sadly not due to having a great workshop at my disposal.....the great bit is ........she,s 350 miles away
Sorry, I jest
Its great when "The Family" support what you are building , nice one
Old 10th September 2010, 10:04 PM
Even the other half thinks it's great, I think she thinks she is going to get behind the wheel, as if I would let her risk herself behind the wheel of something so wild
Old 10th September 2010, 10:17 PM
Just a quick question while you are on here Andy, I am having trouble with my Tig welder is this gas ok for mild steel with a tig set, it works ok with the mig and I was wondering if the problem was with the gas through the set because my the earth, etc all seem to be ok, even checked the collet is the right one for the tungsten etc.
p.s the photo of the cylinder is in the attached
http://s900.photobucket.com/home/TheArf/index
Old 10th September 2010, 10:25 PM
3GE Components's Avatar
Hi TheArf,
Before you get too far in the build, where's this junction in your frame?
Are you sure you've got everything marked out correctly?
Kind regards
John
Old 10th September 2010, 10:30 PM
it is odd..
