Old 12th September 2010, 04:53 PM
rpjg1975 rpjg1975 is offline
Default Dummy shocks
Hi guys,
I'm gonna be making up some dummy shocks to sit my build on and wanted to check the rough size I should make them to me as close as possible to sitting the right height? On a conversation with Handyandy I think he mentioned 14" but can't remember to be sure. Does this sound about right?
Russ
Old 12th September 2010, 05:35 PM
Deanno's Avatar
Deanno Deanno is offline
I was just about to ask the same question.
and what is the dimension of the hole centre to hole centre.
and hole diameter.
Old 12th September 2010, 05:57 PM
Hi folk's
The free length of the standard shock is indeed 14" & ( Eye to eye ), that length will be just fine so as you can get to wheel a rolling chasis about
I guess if you wanted to simulate a completed cars ride height you could reduce them to about 12" or so ?
Never thought to measure the free length of my shocks when I had the engine & gearbox fitted in my rolling chassis
M12 bolt Deano
Old 12th September 2010, 06:26 PM
brilliant, cheers bonzo
Old 12th September 2010, 06:32 PM
Deanno's Avatar
Cheers Bonzo.
Old 12th September 2010, 06:58 PM
Hi folk's
M12 bolt Deano
What he said ^^^^^^
Old 12th September 2010, 07:06 PM
Aim for a bottom rail chassis height of 4 to 4 1/2 at the front and 5 to 5 1/2 at the rear.
