Old 13th September 2010, 06:28 PM
thenorthface thenorthface is offline
Default Anybody seen this chassis setup ? Help
has anybody seen this front end done on a chassis before ? I bought the chassis last week and all I know it's been modified to suit a R1 bike engine but I have noticed the front wishbones plates are they same top and lower (232mm) between the wishbone plates. The rear wishbones have been done to the haynes roadster spec
Will this front setup work ? If so does anybody know where I can get the front wishbones done ? Help please
Old 13th September 2010, 06:35 PM
David_17's Avatar
David_17 David_17 is offline
I would guess it's to make room for the bike engine, the full lot accross the bottom looks closer to the front than normal. The steering rack supports look like a steeper angle etc too.
*updated 7/6/11*
Old 13th September 2010, 08:45 PM
what you thiout think about the wishbones plates being the same higher and lower ? do u know if this has been copied from a locost builder ?
Old 13th September 2010, 08:59 PM
David_17's Avatar
I think the hole centers will probably be the same height, just closer together. You'd need to measure.
*updated 7/6/11*
