Old 15th September 2010, 11:56 AM
traveler.77 traveler.77 is offline
Default CVH broken plastic distributor spindle.
I decided on a donor and realised I would probably be doing at least a partial rebuild on the engine (for peace of mind). There was this 1992 sierra 1.8 CVH on e-bay with a blown head gasket. I bid on it and brought it back home. The guy had stripped it all down and the good news was that all the bits were there. The bad news....the rotor arm plastic drive off the end of the camshaft has been broken!
in fact, really bad news as I've found out that the part is obsolete at Ford Parts dept. so new ones cannot be bought.
Does anynone have a spare they don't need and are willing to sell it!!!!!!!!!
Old 15th September 2010, 07:52 PM
snapper snapper is offline
If you can't get one try a Megajolt, I believe the CVH has trigger wheel and vr sensor already
Old 15th September 2010, 08:11 PM
les g les g is offline
Mark who posts on here
maybe willing to sell you his
as he has just blown his cvh up
and is replacing it with a zetec
cheers les g
Old 15th September 2010, 08:38 PM
cheers les g
I would have but unfortunately all that went in the bin when i stripped my donor as i ran mine with megajolt and bike carbs, maybe adrian h can help as he is running on cvh and i think he has a spare engine
Old 16th September 2010, 07:25 PM
big_wasa's Avatar
big_wasa big_wasa is offline
mega rare does that mean there worth owt
Nowt again.
Old 17th September 2010, 09:39 AM
Default Broken spindle...
Thanks for your replies/help guys, it's appreciated. "Megajolt"...will research that alternative. It would be nice to have the original ford part anyway, as a back up even if I go the megajolt route to get round the problem. Big Wasa...thanks for the spindle photo! Are you willing to sell me it!!
Best regards to all..
Old 17th September 2010, 02:06 PM
big_wasa's Avatar
yep hence the photo.
Nowt again.
Old 18th September 2010, 11:42 AM
Default CVH Distributor Spindle
Are you today if I call to give you some cash for the spindle?
Old 18th September 2010, 12:51 PM
Default message edit
Are you in this sat or sun (19 Sept) if I call to give you some cash for the spindle?
Old 24th September 2010, 02:40 PM
Thumbs up Big THANKS! big wasa
Many thanks for your help big wasa, your distributor spindle arrived today safely intact. Brilliant..I can finally get my engine running!
Cheque's in the post...
All the best,
