Old 19th September 2010, 04:07 PM
Deanno's Avatar
Deanno Deanno is offline
Default Loom
I' am going to use my Escort mk5 XR3i Engine and thought it would be better to use the escort loom is there any problems with this?
Dean
Old 19th September 2010, 09:21 PM
No problems if you know what you are doing. The main trouble area, if you don't know what you are doing, is going to be coupling the escort loom to the Sierra column switches (is that what you are using, you didn't say?).
Another problem will be to ensure that the rear fog light only comes on when the headlamps (either dip or hi beam) are on, and that the switch lights up when this happens, and not at any other time.
Premier looms (probably the main supplier) use a relay to achieve this.
Old 19th September 2010, 09:24 PM
build a customloom, and mate it to the engine mgmt loom.
Old 19th September 2010, 09:26 PM
Deanno's Avatar
Cheers for that,
I'm planning on (If possible) to mate up my escort steering switches to the sierra steering column.
ant the lights will be the same as the Escort's regarding the fog light.
Old 19th September 2010, 09:57 PM
If your donor loom is setup so that the rear fog light can be activated when only on "side lights" ( as older cars may have done ) then it will fail the IVA requirement,
As Mr H has said, the rear fog light must only be operable when using "Dip or Main " headlights, its a new requirement on the new IVA ( older SVA test would have allowed it ).
Old 19th September 2010, 10:04 PM
(If possible)
Well, that's the problem. Almost anything is possible, including what you want to do. Whether it will be possible for you to do it we can only guess at, as you haven't siad anything about you abilities with car electrics. The mere factt hat you are asking the questions makes me a little bit concerned on your behalf. Do you have a fallback plan if it doesn't work out?
Sometimes with projects like kit car building it can be better to just buy the right thing to start with, and spend the hours you have availble for your build in areas where you can make more progress. (The right thing, by the way, is a Premier loom)
Old 19th September 2010, 11:01 PM
les g les g is offline
if you are going to use the escort loom
why not use the escort column and switch gear
if you can build a haynes roadster mating and mounting the escort column
will be within your capabilities
then just sort the fog light out
cheers les g
Old 20th September 2010, 10:23 AM
Deanno's Avatar
Mr H i would be using the escort column switches sorry forgot to say.
I would of prefered to use the escort steering column but was not sure as ideally i want to stick to there book.
with regards to the fog light is'nt that the same for road cars so would that already be done on the escort when it was made?
Me and electrics are like electric and water were not the best match
Thank you for all your help.
Old 20th September 2010, 10:43 AM
I can't tell you what the Escort set up is, and I guess it's not possible to test it on your donor, all I can tell you is what the IVA requirements are, and thise are as stated above.
One way of proceeding would be to go ahead and see what happens when it is all working, and deal with it then if the fog light comes on with the side lights as well, or maybe find out from another Escort owner
I just checked with my M reg Volvo, and that would be ok, rear fog only with headlights
Old 20th September 2010, 12:43 PM
Deanno's Avatar
i'll check next time i'm down my dad's house as the car is there should be able to check it as the only reason it's off the road is its needs an MOT.
Thanks for your help
Dean
