Old 20th September 2010, 05:58 PM
robo49 robo49 is offline
Default Scuttle
Sorry if this is a silly question
I am about to strip down my chassis after mock up to paint and just had a thought. If I am fitting a fibreglass scuttle ( I haven’t bought it yet having no space to store it)do I have to put a frame work under the scuttle to support it welded to the chassis or do they support themselves
Any advice would be greatly appreciated
Rob
Old 20th September 2010, 06:07 PM
Rob
They are self supporting Rob, 2 layers of 450 gsm matting gives it a lot of strength and stiffness, also there is a flange to sit on each top rail to fasten down.
Nothing to worry about......AndyH
Old 20th September 2010, 06:19 PM
Thanks for the quick reply Andy that’s saved me a lot of work
Many thanks Rob
Old 20th September 2010, 06:56 PM
David_17's Avatar
David_17 David_17 is offline
Can anyone tell me if i've got my scuttle in the right place?
I've found it's longer than the book one, so if the front lines up where it says in the book, then the dash end sticks out too much.
Do i line up the chassis upright with the back corner of the scuttle (dash side) ??
Anyone got a pic??
*updated 7/6/11*
