Old 21st September 2010, 07:23 AM
trickydicky0_16 trickydicky0_16 is offline
Default sierra lights switch
Daft question can anybody tell me what wires to the 2 spade terminals on top of the sierra stalks. lights/wipers sorry if this as been asked already.
regards
tricky
Old 21st September 2010, 08:21 AM
Are you planning on having wipers?
If not then you may as well ditch the stalks an fit a simple 2 stage rocker.
Old 21st September 2010, 09:54 AM
David_17's Avatar
David_17 David_17 is offline
Sounds like the horn to me. 2 brown wires going to a floating connector bloc?
Stick your multimeter on and press the horn
*updated 7/6/11*
Old 21st September 2010, 10:26 AM
They seem to have somthing to do with lights
Old 21st September 2010, 09:57 PM
I believe they are pins 31 & 31a flat spade terminals
Old 26th September 2010, 12:29 AM
gaz05 gaz05 is offline
If you look at them closely you'll see that they are stamped 55 and 31.
31 is an earth (Brown) and as far as I can see 55 doesn't have any connection.
I'll have a better look at the book tomorrow when I'm sober.
Gaz
Total cost so far
Materials £3,150
Tools £855
Old 26th September 2010, 08:02 AM
cheers for that, athough i have now given up and gone for savage switches, does anybody know of any iva issues
Old 26th September 2010, 03:03 PM
Yes, make sure at least something on the dashboard (instrument lighting, maybe) comes on when you switch the sidelights on.
Make sure the rear foglight warning light on the dash (or in the switch itself) only lights when the rear foglight is on, and that that is only when you switch it on, AND either the dip or main beams are on, and at no other time.
Old 26th September 2010, 03:34 PM
many thanks
