Old 27th September 2010, 01:01 PM
Default p clips
check these oput, will they be any good for the brake and fuel lines????
http://www.screwfix.com/prods/25890/...ps-Pack-of-100
Old 27th September 2010, 01:05 PM
or these
http://uk.rs-online.com/web/search/s...302+4294955677
Old 27th September 2010, 01:20 PM
Myself & Gus used the RS component clips for fuel & brake lines. So you should be fine with them.
Old 27th September 2010, 01:48 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
you can get them quite cheap from maplin and also halfords have started doing brake pipe and clips and unions
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 27th September 2010, 01:51 PM
davidimurray's Avatar
Slight change of topic, but if I have wires, running inside split conduit, is using zip ties to attach them to frame rails acceptable or do they have to be P clipped?
Old 27th September 2010, 02:31 PM
Twin's Avatar
Twin Twin is offline
The red one's look like they don't bend for the holes to meet up
Twin
CSF £857.19
Twins Roadster
Old 27th September 2010, 02:32 PM
David,
When I was helping Gus wire his car we put all the wires in conduit as you describe. We then riveted some cable tie bases to the chassis rails, and zip tied the conduit to it.
Old 27th September 2010, 05:06 PM
tkpm tkpm is offline
These P-Clips are meant to be used indoors on fire control systems the red coating can crack when the clips are closed up.
I have bought plastic ones from Maplins as well.
Terry
