Old 27th September 2010, 07:27 PM
shh120m's Avatar
shh120m shh120m is offline
Default grp rear chassis
hi guys, sorry to ask , but i cant find a tutorial for converting the rear tub to the glassfiber one, just wondered if there is one?
Old 27th September 2010, 07:58 PM
David_17's Avatar
David_17 David_17 is offline
Here's HAndy's measurments that worked fine for me...
long rear box tube = 99cm
the 2 spars from RS14 to the 99cm tube = 17.6cm, set at 5 degree,s upwards.
the 99cm tube is an odd dimension which is to allow the inner radius curve of the grp tub.
Got any piccies yet?
*updated 7/6/11*
Old 27th September 2010, 08:07 PM
shh120m's Avatar
cheers bud,
is there still an upper frame to make?
got loads of pics but need to start a blog
Old 27th September 2010, 08:25 PM
David_17's Avatar
There's no need for an upper frame as the grp supports itself, you can pop round for a look sometime if you're passing
*updated 7/6/11*
Old 28th September 2010, 07:29 PM
shh120m's Avatar
cheers, i might be up your way this weekend if im not forced to work.
That back end looks awssome, think im gonna go for white.
