Old 28th September 2010, 10:13 PM
Locky Locky is offline
Default Angles
May seem a daft question, but what is best used to measure the angles on the box section so i am gutting at the right degree?
Cheers.
Locky.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 28th September 2010, 10:19 PM
Twin's Avatar
Twin Twin is offline
Good luck gutting 25x25 box! I struggle with rabbits
Twin
CSF £857.19
Twins Roadster
Old 28th September 2010, 10:28 PM
This will do every angle you need to cut, it's what we use every day to make the compound cuts and to set the lathe for the fish mouths on the wishbone tubes.
http://cgi.ebay.co.uk/RAIZO-STAINLES... 7920252347287
Old 28th September 2010, 10:33 PM
Twin's Avatar
just got one!
Twin
CSF £857.19
Twins Roadster
Old 28th September 2010, 10:40 PM
I prefer the one available from Machine Mart as it allows the steel rule guide to sit ontop of the steel box section (as it is stepped) and so ensures the guide is set at the angle using the steel to be cut as the horizontal plain.
A little more expensive but very robust & accurate.
Old 29th September 2010, 05:19 AM
Coozer's Avatar
Coozer Coozer is offline
One of these any good? Nice and robust and cheap..
http://www.toolstation.com/shop/Hand...0/sd150/p84416
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 29th September 2010, 11:40 AM
I have got one of these cant fault it perfect angle every time to 0.00 deg
http://www.axminster.co.uk/axminster...er-prod783404/
Old 29th September 2010, 06:16 PM
Thanks all, i may go for the one talonmotorsport mentioned. cheap and looks decent quality. i wont be using it for much else.
Cheers.
Planning Stage
