Old 29th September 2010, 06:10 AM
misty misty is offline
Default diff ?
Hi all
I have just taken del of sierra diff and all the parts with it
now, looking over the diff i can't see any codes letters numbers the tag has nothing on it
how can i find out which diff it is has anyone any ideas please
many thanks
Old 29th September 2010, 06:25 AM
Originally Posted by misty View Post
Hi all
many thanks
How about counting the number of turrns of the input flangethat are required for one complete revolution of the output shafts (averaged if it's different for each side)? Would that do it?
Old 30th September 2010, 10:14 PM
tex tex is offline
if you take the cover off the back there should be painted numbers on the crown wheel (think thats the big gear bit) )
Old 30th September 2010, 10:23 PM
If there aren't, and if he's got the cover off anyway, then if he can see, or feel with something, the pinion, he can just count the teeth on the pinion and the crownwheel, divide the latter by the former and get the ratio.
Easier just to turn the input flange and count the turns needed to get the outputs to turn one full revolution, though.
Old 2nd October 2010, 07:52 AM
Question sierra diff
Hello All
need help with this one if anyone can help
bought a sierra diff and shafts all no prob
on the diff no info at all tab is there but nothing on it
how do i find the type of diff ie 9
need help please
Old 2nd October 2010, 10:24 AM
Trif's Avatar
Trif Trif is offline
This might help you.
http://www.sierraclub.co.uk/mechanic...types-t98.html
My build diary
http://andytrifroadster.wordpress.com/
Old 2nd October 2010, 11:54 AM
Assume you didn't like the answers you got here?
http://www.haynes.co.uk/forums/showthread.php?t=5109
Old 2nd October 2010, 12:23 PM
The advice given in that thread is really the only positive way of telling your diff ratio
There is a list of the different diff's fitted to the Sierra in the Haynes manual .... Not really the propper way to ID a diff that may not even be the one originally fitted to the car !!??
Sometimes you can give the ID tag a good clean with some sand paper, if not too corroded you may be able to read the markings.
That said, still not proof that that was the tag originally fitted ( More so if it has been sold as an hard to find low ratio one )
Counting turns/teeth is the only sure way .... Most of the time the ratio markings are still visible on the crown wheel but that would still assume that the diff has never been meddled with.
If you really need to know & none of the advice given, floats your boat, perhaps a visit to a gearbox specialist will put your mind at rest
Old 2nd October 2010, 02:45 PM
Thats super i will try all those
many thanks
Old 2nd October 2010, 02:53 PM
Hi All
i have managed to find numbers on this diff if anyone can help that would be great
85gg bc 382
4a 10u9 1266
f11/2
0046 a
i have not got a clue what these are
please help
