Hi guys,
need a bit of help, as you can see from the pic I need the bit that joins these 2. not sure what its called or where I'd get it from, any advice would be cool cheers. ![]() |
Spring is missing from inner part of torch where threaded part is close to the rubber,you also need a tip for the wrie to come out,copper coloured.
Hope this makes some sense.
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
If it's the hobby torch I'm thinking of it's all there just you have the wrong shroud. The chrome part should screw straight on to the brass swan neck. There should be cork type insulator inside the shroud with a copper or brass fiting with the same thread as the swan neck. You also need the correct size tips for the wire to come through. The complete set up looks like the pic in the ebay listing.
http://cgi.ebay.co.uk/HOBBY-MIG-WELD...em230633 2d58 or http://cgi.ebay.co.uk/Hobby-Mig-Torc...em230a8a 092b
Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334 |
I have the tip, just never put it in the pic
machine mart for a tip and shroud ( if it is the wrong one )
| Thread Tools | |
| Display Modes | |
