Old 17th October 2010, 07:05 PM
rapidtornado's Avatar
Default Catalytic Converter Query
Not a whiz on all things exhaust so thought it best to ask the experts....
Taken my exhaust off the donor this weekend, the cat conv looks a bit bulky and I was wondering if I could use a cat from a different vehicle on the roadster instead of the donor cat?
I'm just wondering if the cermaic honeycomb is specific to the car or is it age related i.e. I could take the cat off say a rover 416 and use with my twinky engine
Any advice would be appreciated as always
rapid
Old 17th October 2010, 07:32 PM
Tatey's Avatar
Tatey Tatey is offline
Have you considered using a motorcycle exhaust silencer with an inbuilt cat? As it means that you wont need to have a separate cat hidden somewhere else on the car.
However depending on the exhaust length this may affect the designed cat light off temp so it not be enough to keep emissions down when the engine/exhaust is cold. I'm unsure as to how stringent the emissions tests are for cars so you may be able to get away with it.
Old 17th October 2010, 07:36 PM
If your engine was manufactured before September 1995 you do not need to use a catalytic converter. ( Even if one was fitted to the donor car )
That is my understanding of the rules ( Unless they have changed recently )
I guess if you really wanted too, you could fit a cat from another car but would probably need one from an engine of similar engine size.
Old 17th October 2010, 07:47 PM
Didn't know that Bonzo, the car is a 1993 so if your statement is true... happy days!
Can anyone confirm this one? If not then the bike exhaust is a good shout, didn't think of that cheers
Old 17th October 2010, 08:00 PM
Tatey's Avatar
You wont need a cat rapid
Old 17th October 2010, 08:12 PM
So long as you have your donor v5 with the correct engine number.
Old 17th October 2010, 08:23 PM
I keep reading stories about VOSA & DVLA tightening up on the proof of engine age .... I believe that some centrers are now insisting on documetary evidence from the engines manufacturer !!??
Guess the problem with a V5, the engine may have been changed for a later unit ( Not absolute proof of the engines date of manufacture )
Must stress though, it is ony information taken from the net & as such, I do not know for a fact
Old 17th October 2010, 08:27 PM
If it's a ford, then the engine number is part of the VIN. so you can prove the original engine is used.
Old 17th October 2010, 08:48 PM
This is how i proved age at iva with no probs, but as always no two test centres are the same so i wouldnt bank on it
Old 20th October 2010, 08:45 PM
Big Vern Big Vern is offline
V5 doc alone will no longer normally be accepted as proof of engine age. This is because of the large number of people during the SVA years who tried to get round emissions test by registering the donor with a different engine then building their kit.
With SVA, emissions was based on age of donor vehicle and assumed the engine was the original type for that vehicle. Too many people got caught building kits where it was blatantly not the original type of engine from the donor.
As TT says, where you can prove the donor engine is the original from the donor car then V5 doc may be accepted.
It should not, however, be a problem to get written conformation from the manufacturer of the engine as to it's age and this will be accepted as proof.
