Old 18th October 2010, 06:27 PM
David_17's Avatar
David_17 David_17 is offline
Default Some progress at last!
Well, started back at work last week, so things can continue on the build. Today was a great milestone for me - Got the engine running!
Think it may be only running on 3 cylinders, but its hard to tell with a loose exhaust manifold and whilst keeping the engine running with the throttle (needs fully mapping still).
But atleast it runs which is a start!
Video http://www.youtube.com/watch?v=oMx_HFOFP8M
*updated 7/6/11*
Old 18th October 2010, 07:09 PM
tkpm tkpm is offline
Looking good
Can't wait to be at that stage
Terry
Old 18th October 2010, 07:10 PM
I'd say it was running on 3 or maybe 2 lol. congratulations though, all down hill now
Old 18th October 2010, 07:27 PM
David_17's Avatar
Cheers guys.
Forgot to mention, i have an inline fuse holder going to the middle wire of the coil, which keeps blowing (5 amp fuses). Any ideas why? Something to do with the missfire??
(i took it out in the end as i only had 2 fuses)
*updated 7/6/11*
Old 18th October 2010, 08:22 PM
big_wasa's Avatar
big_wasa big_wasa is offline
Thats more like running on 2 but a great start. Is it carbs or Tb's check they are ballanced as that can make a big differance.
Nowt again.
Old 18th October 2010, 08:31 PM
Well done Dave , nice one
Can,t believe how quick your build is progressing
soon be 4 Roadsters on the road within 10 miles of eachother
It,ll be a fun summer next year
Old 18th October 2010, 08:33 PM
David_17's Avatar
Thanks guys, what's the first things i should check to get all 4 cylinders firing? Any tips?
(forgot to add, it's running throttle bodies and MS1)
*updated 7/6/11*
Twin's Avatar
Twin Twin is offline
i've got a long way to go
Keep up the good work bud
Twin
CSF £857.19
Twins Roadster
Old 18th October 2010, 09:16 PM
Cool Well done
Well done David, that is a huge milestone to reach
You have certainly come a very long way in a short space of time.
Apart from checking all of the wiring connections & plug leads, perhaps you will be able to find someone willing to share a basic map for your MS1
Sure you'll soon get it running spot on
