Old 20th October 2010, 07:34 PM
chrisxr2 chrisxr2 is offline
Default whoops
Pulled my dipstick out to check the oil today before taking the roadster out and the bottom of the dipstick snapped of and tinkled off into the sump. Bugger. Tried everywhere to get a long magnetic attatchment to try that, looks like draining the oil and then probably removing the sump, not good. Anyone know if i will need a new gasket for the sump?? or is there one? 1.6 pinto engine.
Old 20th October 2010, 07:57 PM
Twin's Avatar
Twin Twin is offline
I've snapped the handle off mine
Twin
CSF £857.19
Twins Roadster
Old 20th October 2010, 08:28 PM
Big Vern Big Vern is offline
Ahh that'll be because you don't have the dipstick tube bolted up to the manifold properly. The tube rotates and the bottom of the dipstick rubs against the crank web which wears it away.
This happened to me many years ago with a MK3 cortina. I found out the hard way. Didn't realise it had broken off so topped up the oil. (unbeknown to me nearly 8 litres of oil in the engine intead of the usual 3 and a bit) Dashing to work one morning - oil and smoke everywhere. Stripped engine only to find aprox 30mm of dipstick lying in the bottom of the sump
Doubt you'll get it out though with a strong magnet you might be able to 'slide' it allong to the drain hole. Might be worth a try before taking the sump off. New gaskets should be available from Ford dealer, local motor factors or Burton power.
HTH BV
