Old 21st October 2010, 11:17 PM
mikemph mikemph is offline
Default Steering rack threads?
Just been making up my rack extensions today. I have made them m14x2.0 on ball joint end and drilled the other end but is the trackrod end m14x2.0 or is it finer?
Old 22nd October 2010, 08:44 AM
What grade of steel are you using for your extensions? If it's too soft the threaded section will snap off.
Old 22nd October 2010, 10:06 AM
Hi Mike,
The mk2 racks are metric M14 x 2mm, it is the mk1 racks that are imperial threads. They also want to be 125mm long.
Regards....AndyH
Old 22nd October 2010, 03:39 PM
you havent mk1 bits have you there inferial (1/2 unf ?)
i got a new mk2 rack of the bay turned out to be a mk1
Old 22nd October 2010, 04:51 PM
I have used bright drawn steel is that strong enough? If not I'm sure I could get hold of some high tensile bolts from stores at work. I could then turn them down to size.
Old 22nd October 2010, 05:06 PM
That will be fine Mike, Rally Design ones are a light alloy and they are fine.
Regards...AndyH
Old 22nd October 2010, 05:17 PM
That's good news as I have made them already
