Old 28th October 2010, 09:47 PM
davidimurray's Avatar
Default Dash Lights - what do I need?
Just been working out what lights to have on my dash as I have 8 available on my dash.
Was thinking of -
Left Indicator
Right Indicator
Oil Pressure Warning
Charging Warning
Brake Fluid/Handbrake Warning
Sidelight
Main Beam
Fog Light
Hazards will be the switch on the steering wheel.
Is this all I need??
Old 28th October 2010, 09:49 PM
Full Beam??
David_17's Avatar
David_17 David_17 is offline
I dont think you "Need" oil pressure and battery warning lights.
*updated 7/6/11*
Old 28th October 2010, 09:51 PM
Left Indicator + Right Indicator
Sidelight ( dash illumination is all you need )
Main Beam
Fog Light
Old 28th October 2010, 09:52 PM
They are the two that I would keep over any. Unless your being sarcastic.
Old 28th October 2010, 09:55 PM
The question is "what do you need", if you need to pass IVA , you don't need Oil or battery warning.
Although the alternator does need something to excite the windings.
Old 28th October 2010, 09:58 PM
Cheers guys for the quick responses - I am using one of these units
Supplied by saturn complete with a sensor to go straight into the gearbox. The warning lights around the side are little hexagonal units you can swap or make your own to suit - you get these in the pack
The only thinh you have to be careful about is that 4 LEDs on one side are +ve switched and the 4 on the other are -ve switched.
Old 28th October 2010, 09:59 PM
David_17's Avatar
I was talking about IVA. The others are required.
*updated 7/6/11*
Old 31st October 2010, 09:34 AM
aerosam's Avatar
aerosam aerosam is offline
Dai,
your charging circuit won't work with an LED, it has to be an ordinary bulb (unless a certain resistor is used as well) which I guess is why a battery emblem isn't included with the vapor dash unit.
All the best,
Sam
Old 31st October 2010, 10:09 AM
What price an engine for the sake of one light ?
Fit the brightest red/orange light you can for the oil pressure,you are more likely to see this than watch the oil pressure drop on a guage and it does not take long to wreck an engine due to it.
Can you use one light for both indicators?
