Old 4th November 2010, 08:41 PM
s14a s14a is offline
Default My 1st 200sx Ca18det Build
Hi Guys
Ive finaly desided to take my 200sx off the road and use it as i donor,
Here it is
Its completely standard and only covered 67k this is my 3rd s13 200sx i also have some other parts from my s14a 200sx i would like to use if possible like the LSD,shafts and the bigger s14 turbo.
I have rebuilt many cars but this is my 1st kit car so i have cheated buy using a semi completed chassis that i can modify.
Any advice and input will be greatfully taken onboard
Thanks Alasdair
Old 5th November 2010, 07:06 AM
Welcome to the forum
No advice to offer as yet, 'cos you don't seem to have hit any problems yet!
I assume the chassis is Sierra based, and that the idea is to incorporate as much of your donor running gear as possible?
Old 5th November 2010, 08:28 AM
Welcome to the forum Alasdair.
Lots of helpful folk on here & a very friendly forum.
I,m sure when you have a question someone will be along to help .
best wishes with your build.
Old 5th November 2010, 08:40 AM
Thats is the plan at the moment the less sierra parts i need to buy the better
The front arms will just be the usual set up but the rear track will be a bit wider using the s14a diff and shafts so i will need longer arms on the rear
Ill cross that when i get there as for now im going to lay the drive train out and see wot needs modifyed on the chassis to make it fit.
