Old 4th November 2010, 08:45 PM
rjacek02 rjacek02 is offline
Smile Zetec 2.0 blacktop with gsxr750 trottle bodies
Hi
What do I need to connect bike trottle bodies with zetec engine.
I need megasquirt ECU. That I know . Which one is the best?
Which sensors are needed.
Regards
Jacek
Old 4th November 2010, 09:09 PM
David_17's Avatar
David_17 David_17 is offline
i've got gsxr throttle bodies on mine, gsxr ones can be spaced, so can be adapted to fit a st170 manifold instead of making a custom one.
I used all standard sensors from the zetec appart from the tps off the itbs.
*updated 7/6/11*
Old 4th November 2010, 09:37 PM
Which Ecu have you got?
What to do with the ignition?
Old 11th November 2010, 09:06 AM
microsquirt or megasquirt2 would be sutable
