Old 7th November 2010, 03:17 PM
Trif's Avatar
Trif Trif is offline
Default Rear wishbones
Can anyone help
I Just about to start work on my wishbones. I've noted from other threads that the book dimensions are out by 10mm so I've got the updates from the announcements section. When I compared the updated drawings to the book they are identical. My book shows its print date as 2008 revision. Does this revision have the revised drawings in it OR have I downloaded the wrong plans.
Trif
My build diary
http://andytrifroadster.wordpress.com/
Old 7th November 2010, 04:02 PM
Trif's Avatar
Cheers adrian
391 in my book, I'll start cutting
Trif
My build diary
Old 16th November 2010, 05:55 PM
mikemph mikemph is offline
Be careful if you use the the jigs from the book, mine has the correct wishbone dimensions but the jigs are not correct.
Old 16th November 2010, 06:54 PM
squbti's Avatar
squbti squbti is offline
great tip mike, it took me some time to realise when i made my jigs that some of the jig drawings where not right.
