Old 24th November 2010, 11:55 PM
mabautouk mabautouk is offline
Default Granada rear hubs diff shafts same as sierra ?
just wondering if any one knows the answer if sierra and granada have the same rear hub carriers and diff ?
Old 25th November 2010, 01:22 AM
I've heard you can fit a Granada LSD into a Sierra, but you have to modify it a bit. Apparently the space between the diff mount plates is wider on the Granada, but it's easy to cut down the mounts.
Old 26th November 2010, 04:07 PM
Tony Tony is offline
yes but likely to be 5 stud on a granny rear end, easy swap to 4 stud though
I did it the other way, got 4 stud hubs and swapped to 5 stud so I could fit VW wheels
Old 2nd December 2010, 12:42 PM
seventhheaven seventhheaven is offline
Default Part Numbers
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at www.super7thheaven.co.uk
Hope that helps - It's a work in progress
Mark
