Old 8th December 2010, 06:49 PM
misty misty is offline
Default wiring
Hi All
just toying around at the moment with this
has any one any idea of the wiring /cables to use ie on a 3 pin 240 volt household plug you have 3 wires approx 3mm thick. what thickness and voltage should be used on the roadster so i can buy miles of red and blue and green well you know what i mean
hope you can help
many thanks
Old 8th December 2010, 07:19 PM
Probably more trouble than its saving you in the long run trying to sort out which wire is which,8 core min 10 core is better.
Old 8th December 2010, 08:01 PM
thanks any particular thickness?
Old 8th December 2010, 08:42 PM
eSteve's Avatar
eSteve eSteve is offline
Default Not quite that simple...
misty,
your opening post is a little imprecise and it suggests you are looking for a simple straight-forward answer to an involved aspect of the build.
Suggest you have a search around the Internet there are many resources to help you out with planning your wiring. For example, have a look here:
http://www.constructorscarclub.org.n...ringpart1.html
for a 'How to wire your car' primer. Part 5 covers wire sizes and may give you some answers.
I hope you have already had a look round our site. If so you should have come across a very good thread in the summer with a thorough wiring diagram and (possible) wire sizes, by davidmurray.
There's plenty of information out there...
Hope that helps.
Regards,
eSteve
Old 9th December 2010, 08:36 AM
JHewitt's Avatar
JHewitt JHewitt is offline
Default good info there
Steve, that link leads to some very handy info, that I am sure will help anyone wiring their car from stratch, I have basic electronic skills and this would help any novice, so thankyou for that I am sure will come in handy for many builders.
Personally I am hoping to transfer my wiring from the donor to try and keep it as simple as possible.
Old 10th December 2010, 10:17 AM
eSteve's Avatar
Default Any use?
misty,
did the link I provided help to answer your 'thickness' query?
Regards,
eSteve
Old 12th December 2010, 08:19 AM
sorry im late in answering YES all sorted now
many thanks
