Old 18th December 2010, 01:24 PM
Default Which other wheels will fit my sierra?
Hi
Just bought my donor--sierra CVH 1.8--I will need some alloys
Are there any other makes which will fit my hubs?
Thanks
Ayjay
Old 18th December 2010, 01:45 PM
SAAB has used the same size wheels at some point, with a center bore a bit wider.
Audi 80 and some 100s had the same bolt pattern (4x108), but narrower center bore (57, you need 63.4). If the wheels are aftermarket, they will have a larger bore and plastic spacers, so they should fit fine.
Also Peugeot/Citroen used the same bolt pattern, but a much smaller offset, so they will not be an ideal choice.
Old 18th December 2010, 08:34 PM
Hi Ayjay, welcome to the forum by the way
I have the same donor as yourself, I bought some cheap alloys off fleabay for £41 ( for all 4), they are originally from a Ford Puma & known as "propeller wheels" & they fit no problem, look quite smart too ( if I say so myself ), I wanted these as they have large spokes & so hide the weedy looking Sierra discs & drums quite well
Old 19th December 2010, 12:25 AM
Default Any others?
Thanks for replies
Does anyone know if 4 stud fiesta ,mondeo or focus wheels will fit?
Thanks
Old 19th December 2010, 01:31 AM
Yup! Any 4-stud Ford alloy wheel should fit, as long as it's 15".
Old 19th December 2010, 10:51 AM
Watch out for older 4Stud as they have a low offset too of about 15mm Like Pug wheels. Does increase the track width though.
Old 21st December 2010, 09:45 PM
Just found some good focus alloys locally (about 1/4 mile away)
Thanks for all replies with advice.
However--Whats the "OFFSET" when talking about wheels?
Thanks again
Ayjay
Old 22nd December 2010, 07:55 AM
eSteve's Avatar
eSteve eSteve is offline
Smile Good Q - could completed builders give wheel sizes?
ayjay,
good question regarding what size wheels fit. I will be buying some alloys at some point. It's good to know the car for which the wheels were intended/taken from, as most people (private sellers) sell their wheels by describing the car they fit, rather than the dimensions of the wheel.
Maybe you could invite members with finished cars to post their wheel sizes. That is; diameter, offset and width, and, if secondhand, the car they were fitted to. The stud PCD should all be the same for all of us, since we all (bar one or two?) have sierra hubs.
With respect to your question on what is wheel offset; this is a snippet from Wikipedia:
"The offset of a vehicle's wheel is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel. It can thus be either positive or negative, and is typically measured in millimeters. Offset has a significant effect on many elements of a vehicle's suspension, including suspension geometry, clearance between the tire and suspension elements, the scrub radius of the steering system, and visually, the width of the wheel faces relative to the car's bodywork. Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
Positive Offset
- The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative Offset
- The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
"Deep dish" wheels typically have negative offset or a very low positive offset.
To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car manufacturer's original offset should be maintained when choosing new wheels unless there are overriding clearance issues."
Plenty of links to info. and pictures here:
Links to wheel offset information and pictures
The actual wheel offset used by builders would of course be useful to know.
Hope that helps
Regards,
eSteve
Last edited by eSteve : 22nd December 2010 at 08:40 AM. Reason: Added last sentence (199)
Old 22nd December 2010, 09:16 AM
John.W John.W is offline
Default ET
hi all, I have just got a set of 6.5j X15 alloys off a XR2 they are 5 spoke 4 stud from a firm called Boss technology the offset or ET is 37 and the tyre size is 195 50 x 15. I will try to upload a pic later
Regards
John
Old 22nd December 2010, 08:53 PM
Default Why is everything hard?
OOOOOOOOOOH!!!!!! DEAR ME!!
why is everything HAAAAARD?
Not just a simple matter of banging on a set of alloys is it?
You'll probably be hearing from me further down the line re suspension geometry.
Thanks
