Old 14th March 2008, 01:58 PM
Chris Gibbs
Default Disk braked Sierra hubs/driveshafts/calippers
Hello folks would anyone have available driveshafts, hubs and callipers for a disc braked Sierra?
I need some
Chris
Old 17th March 2008, 03:46 PM
Chris Gibbs
Just bumping this up - I still need the parts!
chris
Old 17th March 2008, 09:51 PM
Tenlow Tenlow is offline
I have a related question, my sierra parts have drum rears, is that something that can be changed easily or do I need disc brake hubs?
http://locost.us - totally substandard build diary that will never be updated.
Old 18th March 2008, 01:08 PM
Chris Gibbs
You'll need disk braked hubs, the drum braked ones dont have a bracket for the calliper. It might be that just the back plates are different but I don't have one to hand (hence the advert!) to check.
Chris
Old 20th March 2008, 09:39 PM
MTor9? MTor9? is offline
Isn't this the way forward?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...84d964fff79f1b
I hope so, as I was going to heed the good advice of a previous poster 'fit what you've got and modify later'.
Old 20th March 2008, 10:32 PM
Great, that's actually exactly what I was hoping for!
Finding sierra (merkur) parts in the states is hard enough, I was going to be upset if I had to find a new set of hubs to go with my drum rear end.
Old 21st March 2008, 10:57 AM
mconley3 mconley3 is offline
Some interesting brake upgrades for the Merkur.
http://www.key-ideas.com/DG-PBR-Fron...e-Upgrade.html
http://www.key-ideas.com/DG_RearBrakeUpgrade.htm
The above parts are easier to find and cheaper.
Mark
Old 21st March 2008, 11:57 AM
Chris Gibbs
I' ve not seen those before, looks like a good option, what sort of price are they?
Chris
Old 22nd March 2008, 04:14 PM
3GE Components's Avatar
The only problem with these are that they are in line with the original bearing carrier, these are OK if you have enough clearance behind the bracket.
With the Roadster the upper shock/arm mount is in the way. Thats why the uprights are different for disc or drum.
What is needed is a bracket that keeps the bearing carrier in the original position but has the caliper mounts at 90°.
A bit like our ones
ATB
John
Old 23rd March 2008, 01:30 PM
Question Drum-disc conversion
Thanks for the info John, I was hoping this was possible.
I am still unsure if rear discs are the way to go for sva, as isn't it necessary to have a brake bias adjuster, which will not pass sva unless of the automatic type? The setting up of which seems to be a bit hit and miss.
Does that then mean that if I convert after sva I would need new driveshafts and diff?
I would prefer the discs, but only for aesthetic reasons, surely drums on a 600kg car are more than adequate?
