Old 3rd January 2011, 02:16 PM
Default Injection fuel pump
Hi all. What is the best fuel pump to use for a fuel injected Zetec engine? There is a Bosch pump used in more than a decade's worth of Audi, VW, BMW, Volvo and other cars (Bosch parts 0 580 254 9xx), is that the one of those? What fittings required, what diameter fuel pipes, tank outlet are best? What about the filter? Thanks!
Old 5th January 2011, 08:14 PM
big_wasa's Avatar
big_wasa big_wasa is offline
Ive used a bosch copy found on ebay and it runs fine.
mine is 3/8" 10mm inlet 5/16" 8mm outlet.
Mines on a standard 2.0 zetec.
Nowt again.
Old 5th January 2011, 08:17 PM
You need a pump that pushes around 3 BAR, some pumps are designed for higher preasure systems and may overfuel.
Old 5th January 2011, 08:31 PM
i disagree a high pressure pump that is capable of 3 bar or above is fine. the fuel pressure regulator on the end of the fuel injector rail is what sets the pressure.
i got one of these the other day very nice but of kit
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_9780wt_905
Old 5th January 2011, 09:25 PM
Sure the regulator is there for a reason and does a job.
but for example, a pump designed for a K-Jetronic application with mechanical injection is likly to put out 7-8 Bar. Where as the L-Jet based applications (on which the EEC-IV/V is based) is more likly to need arround 3 Bar max.
Best to try an match the pump to a similar application rather than just buying anything. If you have too much flow, and too much pressure then the system won't be able to return the flow.
Old 5th January 2011, 11:26 PM
agreed point made
Old 5th January 2011, 11:53 PM
Too much is not always a good thing..
Imagine this on a 2.0 Zetec.
Old 6th January 2011, 12:32 AM
Here's a catalog of Bosch motorsports pumps with technical data:
http://www.bosch.com.au/content/lang.../fuelpumps.pdf
But my main question is -- how do you join the outlet of the tank (8mm presumably?) with the 12 mm inlet of the pump?
Old 6th January 2011, 06:04 PM
But a reducer from Burton
Old 6th January 2011, 08:14 PM
big_wasa's Avatar
steel reducers bought on ebay. They have barbed fittings.
http://cgi.ebay.co.uk/13mm-8mm-BRASS-BARBED-Fuel-Hose-Joiner-silicone-5-16-/250618993024?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item3a5a0e5980
Nowt again.
