Old 8th January 2011, 09:00 AM
mikemph mikemph is offline
Default Ally footwell panels cp16 cp17?
Is there any reason these panels couldn't be aluminium then be bonded and riveted in position? I am aiming for lightness as it will be purely a track car.
http://m1kemph.wordpress.com<---- build blog clicky
Check us out on facebook. Hamlet Engineering Services limited
Old 8th January 2011, 09:41 AM
I can't see why CP17 can not be made from ali other than it has a moving part behind it. As for CP16 it's probably easier to make in steel as it should be welded to join the angled section that goes around the steering shaft. If you make CP16 in ali I would put flanges on the angled part and either rivet it on or use some M4-5 bolts with nylocs.
Old 8th January 2011, 10:06 AM
dogwood's Avatar
dogwood dogwood is offline
No problem that I can see.
You will need a steel bracket to hold the column bearing though
David.
Old 8th January 2011, 10:09 AM
Welding Ali is not a problem for me... I have access to ac tig and plenty of years welding Ali. I was just making sure there was no structural reason for using steel.
Old 8th January 2011, 01:25 PM
The structural reason is the steering column mount.
The other reason is for protection, but I can't see steel helping much more than ali during a clutch/bellhousing explosion...
Old 8th January 2011, 07:55 PM
I'm going bike engine route anyway so no need to worry about clutch it sits much further forward in the engine bay.
So I need the support the column is the main hurdle to over come or beef up a little.
Old 8th January 2011, 08:10 PM
The pedal box, from the brake pedal and cylinder mounting, takes a lot of force Mike so maybe just consider adding a lug either side of pedal box and fixing to the uprights either side of it to transfer the force to this rather than through the ali panel and upwards on the floor fixing.
AndyH
