Old 19th January 2011, 10:39 PM
Default pedal box
Making a pedal box is a bit daunting for me and they are expensive to buy. Does the pb have to be as book spec or is it possible to modify and use the ones on my sierra.?
Any ideas would be appreciated
Thanks
Adrian
Old 20th January 2011, 08:08 AM
dogwood's Avatar
dogwood dogwood is offline
Hi AyJay
I think you can buy the pedal box ready made for about £100
Check out 3GE
Yes you can make Sierra pedals work, coz thats what I did when I upgraded my Roadster. But it certainly ain't easy...Defo found it harder than making the book ones.
The book pedal box may look a bit daunting, but if you make one bit at a time You'll find it all comes together quite easy.
The box I made when I first built my car >>>>VVV
FYI... the clutch needs to be made from 5mm not 3mm as specified
You'll find 3mm is likely to bend under heavy use
David.
Old 20th January 2011, 11:00 AM
carlknight1982's Avatar
I brought a complete pedal box from John @ 3GE, excellent quality
Roadster No 2 build
Cost to Date : £93
Old 20th January 2011, 12:12 PM
John has pedal box parts listed on ebay
http://cgi.ebay.co.uk/haynes-roadste...item4aa7e613ae
Old 20th January 2011, 12:54 PM
SORTED
I Haven't got the skill or equipment to make my own but I can weld one together!!
Thanks for helpful comments and pointing me in the right direction
Just ordered the bits
Adrian
Old 20th January 2011, 01:16 PM
Oooh, excellent value this 3GE kit!
BTW, I have some PFTE rod, inner and outer tubes left over, I could share 10 cm of each for, say, 7 quid posted, anyone interested? The PFTE rod needs to be turned down from 23 mm to 22 mm in order to fit into the bush tube.
