Old 24th January 2011, 08:59 AM
gaz05 gaz05 is offline
Default Things you wish you'd done different
Started fitting the bushes to the bones and then fitting them to the car. Straight away I was annoyed because the paint on the uprights got scraped away where the bushes/crush tubes rub. If I was doing it again I would make the brackets wider and weld in a washer the same size as the bush on the inside face. That way the paint would be untouched and the face of the washer could be greased for protection.
Crap, put it in wrong section.
Total cost so far
Materials £3,150
Tools £855
