Old 25th January 2011, 09:16 PM
Pavel Pavel is offline
Default Front wishbone geometry
Right, I'm still CADing my chassis but have just attached the uprights, wishbones etc. to the chassis.
I get silly camber (over 5 degrees). I can't for the life of me figure out why this is, as I've used book dimensions for everything.
Could somebody confirm the following dimensions (in square brackets are what I've got):
1) From chassis pivot axis of lower front wishbone to centre of lower ball joint [414.50mm]
2) From chassis pivot axis of upper front wishbone to centre of upper ball joint [260mm]
I'm sure I've got the geometry wrong somewhere, but need to narrow it down.
Thanks,
Pavel
