Old 30th January 2011, 02:56 PM
shonenj shonenj is offline
Default rear tub
Having some trouble with the rear tub - I have cut the piece RP1 to 240mm as per the manual and tacked to chassis, but when I clamped the rails D12 &13 to check all diamensions ok (checked dimension & angles of these parts to book) they appear too long. Is anyone aware that the dimensions for these parts are not listed correctly in manual?
I have D12 as being 359mm with angles 44degrees and 8degrees.
D13 as 357mm with angle of 8degree and radius of 9.5mm.
I haven't cut RP2 as yet to the angle of 24degrees - depth of 355mm as rear just does not look right.
