Old 1st February 2011, 10:43 PM
JakeH's Avatar
JakeH JakeH is offline
Default Been a while
HI
Saying hi again had an account on here a year or so ago however my computer got viruses and hacked, whoever hacked it was using my e-mail and trying to use ebay! took the old computer to get "sorted" but was beyond repair so i got myself a macbook which is awesome also had to get new e-mails, passwords, ebay, and loads of other (what a pain) (old account car.mad)
the names jake im 21, from yorkshire (emley to be precise) training mechanic and starting university in september on a motor sport engineering course.
also had some problems with the build, a heavy rack fell on my tacked chassis and bent twisted and knackered just about every rail on it so i cleared out and started again!
been eventful to say the least, had a major throw out, and change around so i have more space built a new build table and got some new gear.
started on the build at the beginning of January, already have most of the front part of the chassis built up again.
started looking for a donor today but had no luck, went to a few scrap yards trying to find parts and rung every number i could find about buying a full car. everyone i spoke to says they are like hens teeth now, so struggling on that part. if anyone has a spare one knocking around?
will put some photos up soon
Jake
Last edited by JakeH : 1st February 2011 at 11:07 PM. Reason: found suspension brackets from talon
Old 1st February 2011, 11:10 PM
carlknight1982's Avatar
Hi Jake join the sierra forum and piston heads that should speed your donor search
Roadster No 2 build
Cost to Date : £93
Old 2nd February 2011, 08:31 AM
Hi Jake and welcome,
I changed to an iMac last year for home and it is so much better than pc with windows, much better operating system and no problems at all so far....
All the Best...Andrew
Old 3rd February 2011, 12:09 AM
JakeH's Avatar
Got a bit of time today so i prepared a little info on what iv done so far, with some pics and wot-not, comments and constructive criticism welcome.
first a bit of info:
using a 2.0 zetec engine with either gearbox, depending on what i can get hold of. will be turbo charging the engine when its in but for now just leaving it standard, using the original ECU and injection system on the engine.
my car will be for track use only so will be using a full roll cage and strengthening the chassis slightly.
Day One
Sorted the disaster of a garage out today, had a huge clear out, and built a new build table with a nice piece of 38mm MDF for a base.
put up some racking and sorted the pile of steel i had into some sort of order, this time round i'm going to cut ALL the chassis rails by hand, last time i used one of those daft rage saw things which caused more pain than gain, should be fun
Day Two
marked out the build table and chocked it up with some bits of MDF i had lying around, then cut the base rails for the chassis and slotted them into place on the table, didn't get chance to tack them yet as i don't have any MIG gas, will get some tomorrow
Day Three
Tacked all the bottom rails together today then started on the dreaded front frame, had a full day (6 hours or so) and managed to get it as close to perfect as i could! then tacked it to the base of the chassis.
Day Four
Got loads done today, uprights top rails, seat backs and a diagonal or two, starting to look more like car now, making me feel like i'm achieving something again.
Day Five
A good five hours in the garage today saw some more uprights, top rails and a couple of diagonals finished off, its flying together now, because iv already built the chassis once and had a disaster i kind of know what im doing so getting things level and square is proving a bit easier
Day Six
The last of the top rails and diagonals done today, will be adding some more supports to try and keep the chassis as stable as possible under cornering. starting on the seat back next
Day Seven
got the seat back rails done today, and moved the chassis forward ready to start on the rear framework.
Today
ordered the suspension and shocker brackets today from talonmotorsport.
Old 3rd February 2011, 12:29 AM
Hi Jake, welcome "Back" to the forum
Looks like you,re making great progress there
Might be an idea to remove TR5 if you are installing the Zetec ...gets in the way .
Old 3rd February 2011, 06:04 PM
shh120m's Avatar
shh120m shh120m is offline
looks good mate, you arent half going at it, it will be finished by day 10!
Old 3rd February 2011, 06:57 PM
Cool Welcome back Jake
Welcome back into the fold
Certainly looks like you have made some real steady progress, plenty of pictures too
Old 5th February 2011, 10:50 PM
JakeH's Avatar
Day 8
Started on the rear frame today, got the main part of it done, ran out of welding gas near the end so a couple of the welds are a bit well really bad...
Day 9
done some more on the rear frame today, got the plates surrounding the shocker mount and roll bar mount done along with most of the rest of the tubes on the back, another day and i should be ready for suspension mounts.
Also been on the sierra hunt with no joy what so ever, spotted and OLD Y reg one in a garden, tis a bit knackered and has a wall around it so would need lifting out, knocked on the door but no reply (apparently hes a bit of a collector) so might be reluctant to give it up, going to go back and offer to remove it for free.
Jake
Old 8th February 2011, 05:41 PM
JakeH's Avatar
I FOUND ONE
after a week of looking with no joy for a sierra thats both close to home and within my budget i found one! tis a 1991 sapphire, 1.8 only done 88,000 miles, which i thought was'nt too bad! a few pics
found it on gumtree.com, was in bradford, paid a bit more than planned but it was worth it!
including a bit of fuel to get it home paid £300 should be able to make that back selling the parts i dont use!
Jake
Old 11th February 2011, 04:41 PM
JakeH's Avatar
been busy as usual.
got the rest of the rear suspension area done this week, and done the base of the transmission tunnel.
getting there now, should hopefully have the suspension brackets tacked on and make a start fully welding the chassis by the end of next week.
a few (more) pics for your enjoyment:
will be stripping the donor at the beginning of march as we now have 5 cars on the drive but have just ordered a van and are trading 2 of them in, should have a little more space by then!
will also be adding some more support to the chassis as it will not have an easy life! but that will be done after the chassis is fully welded and the engine, gearbox, e.c.t "trial fitted"
