Old 2nd February 2011, 11:10 AM
whitstella whitstella is offline
Smile which clutch????
hi
i've got a type 9 gearbox with bell housing, but i seem to be short of the clutch arm. does this come with a complete clutch kit or have i got to find 1 seperate????? the engine i will be using is a 2l zetec with hopefullt a 1.8l fly wheel. what clutch kit do i need and release bearing???
cheers steve
Old 2nd February 2011, 11:16 AM
jasongray5's Avatar
On my 1.8Zetec im using a standard mondeo clutch kit, but longer release bearing. Will try and find you the part number
Old 2nd February 2011, 11:21 AM
jasongray5's Avatar
Part No. CCT113. Its from a capri so that should help your search! Good luck!
Old 2nd February 2011, 06:44 PM
is it heavy at the pedal with this pressure plate?
i will be using a 1800 silvertop on a type9 and will be getting to this bit at some point
Old 2nd February 2011, 07:42 PM
jasongray5's Avatar
I dont find it too bad? Although if you did, then you could always move the cable down the pedal? if you see what I mean?
Old 2nd February 2011, 10:20 PM
On a 1.8 flywheel, you need Mondeo 1.8 clutch (220 mm disk, 26mm shaft, 23 splines). As for the clutch release bearing, some people make do with a Sierra bearing (Quinton Hazell CCT132), also I've heard some put on two of those, some get the longer CCT133 bearing. Here's a list of part numbers of equivalents in other catalogs: http://www.haynes.co.uk/forums/showt...?t=4036&page=3
Old 2nd February 2011, 11:00 PM
i think you guys are missing something here. he is missing the actual clutch arm not just the release bearing.
the release arm should be with the box you wont get a new one with the clutch and replacements are like rocking horse poo. i would contact the person that sold you the box and ask if they still have it.
Old 3rd February 2011, 01:22 AM
jasongray5's Avatar
True story Ash! They come up occasionally on ebay, maybe keep your eyes peeled, or as Ash says, email the gearbox supplier?
Old 3rd February 2011, 11:56 AM
Usually a few on ebay or Burton power used to do them brand new,links below.
http://cgi.ebay.co.uk/Ford-Pinto-Ral...item41565beed5
http://www.burtonpower.com/
Old 4th February 2011, 01:18 PM
what starter is everyone useing i got a fiesta zetec 1.8 one and a sierra 1.8 cvh one but the pinion clutch is dead so it will be cash for a recon if the fiesta one is no good
