Old 3rd February 2011, 08:57 PM
Andy_B Andy_B is offline
Default Roll bar horizontal and stays
Picking up 5m of erw tube to complete my roll bar horizontal and stays ..its 38.1mm OD i want to run the rear stays to the lower rear corners and weld them to 100mm x 100 x 3mm plates bolted to plates welded to the tub corners...if that makes sense ...that would give me 16 bolts and allow the roll bar to be removed....my only concern is getting a decent weld between the thin CDS tubing and my roll bar mounting plates...has anybody got any advice ...or even better piccys....sure i have seen this done on one of the many build diarys i have read somewhere !!!
