Old 14th February 2011, 11:16 AM
misty misty is offline
Default rev counter
Hi all
do i need a rev counter and if so which one should i go for .i hope to fit a 2lt pinto
many thanks
Old 14th February 2011, 03:21 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, you dont actually need one but it is one of the more important gauges.
without one youll never know if your hitting max revs, pintos dont like to be over revved they will break if you reguarly go over 7k
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 14th February 2011, 04:30 PM
many thanks that is all i need to know will get one
thanks again
Old 18th February 2011, 12:53 PM
aerosam's Avatar
aerosam aerosam is offline
thanks again
I'm using one of these - easy to install and cheap too!
Old 18th February 2011, 05:44 PM
Ray
You don't necessarily want to hit Max rev's anyway. You need to know where the power band peaks and this should be the upshift point.
