Old 15th February 2011, 10:13 AM
jimmy jimmy is offline
Default grp conversion?
hi, has anyone used a grp rear panel from saturn sports cars? if so what are the dimensions of the chassis conversion to fit? any advice? chears
Old 15th February 2011, 10:57 AM
jasongray5's Avatar
The way I did mine, was no support frame for the rear tub, then put it in place, have abit of a measure up, and then fabricate it to suit?
Dont know what others have done tho?
Hope that helps mate
Jas
Old 15th February 2011, 11:47 AM
fabbyglass
I'm sure Andy at saturn has got a a drawing for the mod or do as Jason did(and me come to that.. ) clamp the panel to the chassis and see where you need to be.
Old 15th February 2011, 12:24 PM
Andy_B Andy_B is offline
http://www.saturnsportscars.co.uk/st...d&productId=68
Saturn sports cars !!
Old 15th February 2011, 12:40 PM
Hello Jimmy,
Good to see you last week, hope you enjoyed your trip out and you're getting on with the build.....
You dont need to buy the bits they are quite easy to fabricate and fit. Link below the thread that gives you all the dimensions and some pics.
Regards....Andrew
Old 15th February 2011, 06:19 PM
Originally Posted by spud69 View Post
Hello Jimmy,
Regards....Andrew
trip out was fantastic, didnt think anything with 4 wheels would ever put a smile on my face!!!!! my left coat sleeve was very dirty tho lol. yeh getting on wif the build slowly got 1 coat of paint left to do on those rear wishbones nd iv just got a set of fzr 600 carbs to pimp the sierra (if it will work)
Old 12th April 2011, 07:54 PM
jmh jmh is offline
Quick question on a similar note.
If you already have a standard chassis in terms of the rear curved bars, will the Saturn rear panel still fit it?
Thanks in advance,
Jonathan
Old 13th April 2011, 12:41 AM
I have this drawing saved from previous.
Old 13th April 2011, 08:28 AM
Hi Jim,
the grp panel will fit over the curved frame but you will need to cut it and add a small section underneath the roll bar mounts at the top of the wheel arch. Aesthetically it is much better to make the mods shown earlier when fitting the rear panel and remove the curved rails.
The fuel tank will need altering with a tapered back to fit inside the panel.
Regards....Andrew
Old 13th April 2011, 07:33 PM
I have modified rear end for GRP tub also. Does anyone have any dimensions for fuel tank? I plan to bring the rear stays down same dimensions as book from the centre line of the chassis, but will locate on the rearmost rail, as do not have round tube as aluminium rear tubs do.
