Old 15th February 2011, 04:55 PM
davylock davylock is offline
Question What sealant to use?
Hi, what sealant does everyone use to seal between the aluminium floor/panels and the chassis rails?. I'm sure someone's said that acrylic sealer damages the panels over time, so do I need to use polyurethane based sealant?.
I see fabby mentioned Sikaflex, I can get EBT for £7.14 locally from S/Fix if that does the trick. Anybody else recommend this make, thanks Dave.
Old 15th February 2011, 05:38 PM
Andy_B Andy_B is offline
i used this stuff from toolstation it sticks like buggery to anything...including hands boots etc etc...i glued to bits of ally together with it and had to rip them apart to break the seal......cheap too !!
http://www.toolstation.com/shop/Adhe.../sd2350/p67949
Old 15th February 2011, 06:16 PM
Davey's Avatar
Davey Davey is offline
You could try Everbuild Stixall, comes in white or clear and it soes what it says on the tin, namely stix all. Will even cure under water. Available from several sources but best price I found was on evilbay.
D.
Old 15th February 2011, 06:38 PM
I used a product called omniseal that I got from my local autofactors. Basically any PU adhesive should do the trick.
Old 15th February 2011, 06:47 PM
David_17's Avatar
David_17 David_17 is offline
Tigerseal is good stuff, not cheap tho.
*updated 7/6/11*
Old 15th February 2011, 07:39 PM
Thumbs up
Thanks all for the input, will google all these and get sorted out tomorrow, Dave.
Old 15th February 2011, 08:48 PM
james3004's Avatar
I got some from ebay it was advertised as a sikaflex equivalent and it did the job very well, it was £8.10 for 2 tubes inc postage
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 16th February 2011, 09:21 PM
we use stikaflex on the bentleys to bond windscreens in and seal spare wheel wells with all the fuel pumps in etc
bloody good stuff
Old 17th February 2011, 09:23 PM
Default sealant
Thanks fellas, finally sorted, I got some Mapeflex PU45 in grey at £6.93 ea. from S/Fix, should be OK, Dave.
