Old 16th February 2011, 11:38 PM
David_17's Avatar
David_17 David_17 is offline
Default Roll bar IVA
Is there any particular spec for iva about the angle of the rear stays on the roll bar? Mine are going to be quite a steep angle, due to the location of fuel tank, pump and filter.
Also does each side need 1 bolt or 2? Ive read both answers when searching, in theory i'd like 2 to be safe, but space is tight.
Hope someone can shed some light.
Dave.
*updated 7/6/11*
