Old 18th February 2011, 07:39 PM
ruffiac1 ruffiac1 is offline
Question Headlight Bracket
Could someone tell me the length of the headlight bracket required for IVA.
This is not listed in the manual
Old 18th February 2011, 07:45 PM
120 mm from center of mount to chassis rings a bell,someone will correct me if wrong.
carlknight1982's Avatar
Mine are 120mm from the centre of the headlight mounthing hole.
Hope this helps
Roadster No 2 build
Cost to Date : £93
Old 18th February 2011, 07:52 PM
Smile
Thanks for the measurements .More questions soon
Old 18th February 2011, 09:04 PM
As Carl & Flyerncle have said, 120mm from the hole center to the outside edge of the chassis rail, if you weld the brackets to the side of the chassis rail ( TR1 & TR2 ) just above the upper shock bracket it will mean you don,t have to cut the nose cone,
if you position the brackets as above, give some thought to how you will route the wiring BEFORE you weld them into place
