Old 20th February 2011, 03:54 PM
Tatey's Avatar
Tatey Tatey is offline
Default Spigot bearing removal
I'm currently trying to remove the spigot bearing from my 1.8 silvertop zetec engine to replace it with the sierra spigot bearing. However I am having some difficulty in removing it. I have tried the molly grease method, of packing the crank with grease and getting something which fits tightly into the bearing and give it a good hard whack to try and force the bearing out. But the grease just seems to ooze out of the sides.
I am trying to use a 3/8" breaker bar as the ground bar as it fits nicely and I have nothing else that will fit.
Has anyone got any ideas as to what im doing wrong or any other methods that are proven to work? I dont have access to a bearing puller, but would be willing to buy one if they are cheap enough. Does anyone have any recommendations for a bearing puller?
