Old 27th February 2011, 12:19 PM
whitstella whitstella is offline
Cool rear suspension mounts
hi just fitted my rear suspension brackets to my chassis yesterday. i made a couple of jigs and when it came to tacking the bracket on for the upper wishbone i had a 6mm gap. so what i did was just packed it down with a piece of steel. and the lower brackets are not in the middle of the of the 25mm box, they are down about 6mm. i looked at the chassis and the bottom rail (BR12) has lifted about 6mm due to welding. (i brought the chassis of greasemonkey) i have checked the measurements from the upper suspension bracket and it is all correct i just measured down instead of from the bottom rail. so the suspension is all ok inrelationship to each other just not in the correct places on the chassis. NOW WILL THIS BE A BIG PROBLEM????
SHOULD I START A FRESH????
CHEERS STEVE.
