Old 3rd March 2011, 09:26 PM
Default Tapered reamer
Gents
Does anyone know the dimensions for the taper reamer? Min Dia-Max Dia and the angle or length? I might be able to get one made up (its not what you know but.......) It can then do the rounds for the rest of you guys, think there is only one in circulation at the moment reading the post on the forum.
Had a scan in the book but may have missed it somewhere.
Leigh
Old 3rd March 2011, 09:31 PM
The reamer is roughly a 2.5 deg tapper if thats any help.
Old 3rd March 2011, 09:37 PM
Andy_B Andy_B is offline
http://www.toolstation.com/shop/Hand...0/sd150/p11421
Would this be any good ?
Old 3rd March 2011, 09:38 PM
Hi Talon
Yes that helps, all I really need to know now is what the min dia. is for the lead on the reamer.
Leigh
Old 3rd March 2011, 09:43 PM
I think thats too small as the bottom of the taper is about 14-14.5mm. The one I used for my uprights is 19-20 at the end, I would say buy 2-3 of the same ball joints from different manufactures and measure very carefuly.
Old 3rd March 2011, 09:47 PM
Ok, so are we saying the reamer needs to be from 14mm(lead) - 20mm (end) at a 2.5 degree angle?
Old 3rd March 2011, 10:02 PM
Ah sorry...... think I might have got my wires crossed here, we are half way through doing a batch of mushrooms which takes the TRANSIT ball joint D'oh.
The reamer for the MAXI ball joint (bottom) is about 2mm one end and 19-20mm the other over 150mm ish.
Old 3rd March 2011, 10:09 PM
les g les g is offline
dont Axminster do one off the shelf for about £7.50
do a search on here there are a couple doing the rounds
we have used them then posted them on etc
cheers les g
Old 4th March 2011, 08:24 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi,heres the link its the large one you want becarefull ordering as i accidently got two super fast delivery and well cheap.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 4th March 2011, 08:40 AM
Hi mate have sent you pm have got one you can loan
