Old 8th March 2011, 12:37 PM
axle's Avatar
axle axle is offline
Red face MT75 box + Vibration damper
Hi all
Has any body with MT75 gear box has bothered to fit the vibration damper or will it be ok without it?
Regards Axle
Old 8th March 2011, 07:36 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
hi that and the doughnut were two of the many things that swayed me to use the type 9 I had instead of the mt75 thats now sat out on the drive.
sorry its not much help but I would try and do away with both not sure if you can get a flange to fit the rear of the box instead of the spider type coupling but that would be the way to go if you can.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 10th March 2011, 12:02 PM
axle's Avatar
Thumbs up
Hi
Thanks for your response, I have had advise from other wise buddies. The damper is no longer necessary when the UJ is removed. I am also having the sliding spline on the prop.
Regards Axle
