Old 8th March 2011, 09:04 PM
james3004's Avatar
Default Steering column Extension
I need one a steering column extension as my donor had PAS.
Found one on Ebay but it says it needs new rubbers, are these readily available?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 9th March 2011, 08:19 AM
Hi James
I don't think that you will find the ruber ring is available as a service part.
Had a sneaky feeling that the rubber ring is riveted in place, I have just been out to check mine & it is definately, factory riveted.
The long & short of it is, you'll probaly have to buy a whole new assembly from Ford
Rally Design do a suitable steering rack coupling though
Old 9th March 2011, 09:49 AM
fabbyglass
Use one of those cheeky wee knuckles from rally design, look better and better clearance wise as bit like those knuckley things in a socket set...
Old 9th March 2011, 10:07 AM
I am with you on that one Mark
Not the cheapest to buy but at least it will get rid of that rubber ring that's going to be about 20-25 years old
You'll find them on this page.
Rally Design
The forged ones are the boys to go for
Old 9th March 2011, 10:23 AM
fabbyglass
Rally Design
Cheers Ronnie I'm far too lazy to go hunting for links .........
Old 9th March 2011, 10:48 AM
james3004's Avatar
So what parts would I need? I'm presuming the sierra coupling, group 4 coupling and a shaft
--- James ---
Flickr Album
Old 9th March 2011, 01:12 PM
Ronnie is defo right,it's a complete assembly with the rubber doughnut.
RD bits and pieces are better.
Old 9th March 2011, 01:39 PM
I guess you would need the Escort coupling & shaft
Would imagine that the Sierra coupling has a spline one end & a triangular bit at the other .... Better suited to joining the extension shaft to the exhisting Sierra triangular lower steering column ??
Not 100% sure on that though .... If I were to have a gripe with Rally Designs website, it would be that there is not enough product information & the images could be larger/better quality
To do a real fair dinkum job, I suspect you'll need, 1 X Escort coupling, 1 X Sierra coupling & 1 X Extension shaft ( A quick call to RD would confirm this ) .... Soon starts to get expensive
If it is of any help to you James,
I belive I have a spare, original Sierra rack coupling here that is still serviceable.
Just need to double check the spline size.
Old 9th March 2011, 02:17 PM
Fogive me James, I think I am being a little bit dim today
You probably have a coupling like this on the end of your column ?
If you have, I guess the most low cost way of doing things would to do the following.
Cut the pice in the photo, midway in the round section ( Circled )
Extend the shaft using some suitable, thick wall round tube.
One end should then join onto the steering shaft & the other end should fit into the triangular end of the Sierra type group 4 coupling.
Still best to check with RD to see if this is the case though
Old 9th March 2011, 08:45 PM
james3004's Avatar
Now I'm confused lol
that's what I have
--- James ---
Flickr Album
