![]() Hi guys,
Is there a guide to stripping the diff anywhere? I want to blast the casing clean and polish it so i thought i may aswell give it the once over at the same time thanks nathan
A few build photos... www.photobucket.com/ntsengineering |
![]() Specialist job to setup diff,preload,pinion mesh ,backlash etc.
Might be better left alone unless it has a problem.
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
![]() Found this somewhere on the net http://web.zone.ee/mopple/Haynes/Sie...l%20manual.pdf
![]() word of advice when it comes to diffs if its not broke dont fix it
i set up one or two at collage not an easy job |
![]() ok, i was maybe being a bit optimistic
![]() Maybe il just plug up the holes and polish or paint it!
![]() seriously, no one is going to be looking at your rear end........
![]() lol...........
Thread Tools | |
Display Modes | |
