Old 11th March 2011, 06:39 PM
XR4BILL XR4BILL is offline
Default new toy
I picked up a new toy this past Wed. http://i271.photobucket.com/albums/j...7/IMG_0715.jpg
I am still going to build one as well.
cheers,
Bill.
Old 11th March 2011, 08:08 PM
Jimmyd Jimmyd is offline
You may need a bit of a thaw before you get out for a run then!!!
J
Old 11th March 2011, 08:10 PM
Nice one Bill
Come on....tell us all about the spec
Looking at the weather you have there it,ll be scary rear wheel drive fun
Old 11th March 2011, 09:28 PM
vetteman1355 vetteman1355 is offline
Where did you get that one Bill, I know there is one for around 6K on Vancouver Island
Nigel
Old 11th March 2011, 09:51 PM
I got this from a guy in Edmonton, its a Lotus 7, 2006.
Its got a crate 302 Ford V8 engine in it, alloy heads, roller cam, Ford 7.5 rearend, Miata rims.
I also got a pile of spares/moulds/engine with it as well. Some of which I am sure I could use for the one I want to build.
I will update the spec in a few days as I am fairly busy just now.
I went for a ride in it last fall and its quick.
The guy is leaving the country and Ive wanted one for a long time now so, I jumped at it.
I have to figure out where to go for insurance yet?
I think a lot of thaw would be the correct thing to say.
Bill.
Old 12th March 2011, 06:44 PM
A pic of whats under the hood.
http://i271.photobucket.com/albums/j...7/IMG_0552.jpg
Bill.
Old 20th March 2011, 09:12 PM
Andy, sorry about the late reply Ive been busy.
re:Spec of the Lotus 7.
GT40 Spec Ford 5.0/302 crate Motor.
Roller Block.
Pro Comp Aluminum/Aluminium Cylinder Heads.
Stress Relieved Con Rods.
Double Roller Timing Chain.
Performance Cam with 6000rpm Redline.
Roller Rockers.
Mallory Ignition.
Edelbrock Performer Manifold.
Holley 650cfm Carburetor.
Holley Hi Flow Water Pump.
Hi Pressure Oil Pump and Remote Filter.
ARP Main and Bigend Bolts.
March Pulleys.
Holley Electric Fuel Pump.
14" K & N Air Filter.
4 into 1 Headers with Moroso Mufflers.
Alum Radiator with Electric Cooling Fan.
RM-6060 Quicktime Bell Housing.
Mustang T5 Gearbox.
Ford 7.5" Rear End with LSD.
Spaceframe 11/4" Main Tubes and 1" and 3/4" Triangulation Tubing.
4 Link Rear Suspension and Panhard Rod.
Unequal Length Front A Arms with Miata Uprights/Hubs.
Slotted Rotors and Race Brakepads on Front.
Chevette Steering Rack with Flaming River U-Joints.
Wilwood Bias Adjustable Floor Mounted Brake Pedal with Dual Master Cylinders and Remote Reservoirs with Residual Pressure Valves.
15" x 7" Miata Alloys with 205/50R15 Front and 225/40R15 Rear Falken Zeix Tyres.
Avo Coil Over Adjustable Shocks with 400lb Front Springs and 250lb Rear Springs.
Fibreglass Body Panels Painted Corvette Yellow.
Roll Over Bar.
Small Luggage Compartment in the Rear.
Kirkey Drag Race Seats with Covers.
5 Point Harness.
6 piece White Dial Dash.
Race Style Mirrors.
Thats all I got at the moment.
Cheers,
Bill.
Old 21st March 2011, 12:01 PM
aerosam's Avatar
aerosam aerosam is offline
Cheers,
Bill.
Not a lot then???
Old 21st March 2011, 01:06 PM
302 cu in in that will give it warp speed......
Old 22nd March 2011, 03:54 AM
If it would stop snowing over here I could go for a blast, but snow is forcast for a few more days yet.
Bill
