Old 12th March 2011, 05:07 PM
james3004's Avatar
Default Rear brake Proportioning valve
Is this what I'm looking for? ( the bit in the middle, it feeds the rear)
Also For the flexi brake hoses, this bit on the donor goes to the caliper is it a concave fitting so i know what euroquip parts to buy?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 13th March 2011, 08:52 AM
Enoch Enoch is offline
Nope, the bit you need is only found on pre abs cars. You don't have to fit one from a Sierra, I am sure other cars use them. If you look in my build diary - www.deepfolly.co.uk you will see what one looks like. It is about 40mm diameter and maybe 60mm long, it is tubular in shape and has a 10mm fine thread fitting at each end. I can't remember where it was fitted in the donor car, my donor had ABS so I had to buy a valve off ebay. It cost me a tenner.
Hope that helps.
Enoch
Old 13th March 2011, 10:09 AM
Corsa have them near the battery,ford fit the in the rear brake lines on newer cars like Focus and Mondeo.
Old 13th March 2011, 10:19 AM
james3004's Avatar
I can't find anything suitable on ebay, so will have to keep looking
--- James ---
Flickr Album
Old 13th March 2011, 10:40 AM
Local scrappy James.....
10x1 mm is the thread size, differences in the pipe end are made with op1 or op 2 concave or convex.
Old 13th March 2011, 04:04 PM
james3004's Avatar
I hadn't tought of that lol
--- James ---
Flickr Album
Old 11th April 2011, 12:18 PM
james3004's Avatar
FORD SIERRA BRAKE BIAS VALVE IDEAL FOR KITCAR WESTFIELD
Is this what i'm looking for?
If it is can some one tell me what angle it is mounted at?
--- James ---
Flickr Album
Old 11th April 2011, 02:00 PM
ThomasDK ThomasDK is offline
Looks like the one I use :-)
Flexi hoses can be bought here: www.mtec-racing.com
i bought this:
4 pipes of pipe length 500mm, all to have A31-3z on one end, 2 pipes to have A23-3z on (convex) and 2 pipes to have A27-3z on (concave)
Paid arround. 50£ I think. cant remember :-)
Hope this helped.
Regards.
Thomas
Old 19th April 2011, 09:55 PM
james3004's Avatar
Default Which way round?
Enoch - what way round does the valve go? from looking at the diagram on the ford microcat, it is the opposite way to what you have it?
--- James ---
Flickr Album
Old 20th April 2011, 08:13 AM
The pressure reducer fitted to the Ka in the rear brake line is ideal and much smaller than the original Sierra one and is easily placed out of sight in the rear feed line (and there are plenty lying around in the scrappy).
