Old 15th March 2011, 11:59 AM
Andy_B Andy_B is offline
Default HELP !! Diff fitting !! or not...
Morning all...been out in the garage trying to fit my diff...eventually got it up into rough position ...drivers side aligned perfectly and bolted up...passanger side is out by about 12mm on the large side..ie diff is 12mm wider ...now i cant ease the holes on the chassis as the diff is smak on center where it is with a nice equal gap both sides...so do i cut the chassis mount off and re fabricate...or can i loose some beef from the top of the diff ...bottom bit is ok as it needs 12mm worth of spacers to pack it out ....hope this makes sense...am just calming my temper down a bit !!
Old 15th March 2011, 12:30 PM
loony's Avatar
loony loony is offline
Looks like you have 7,5" Scorpio/Granada diff... not Sierra 7".
Top mount of 7,5" diff is.... about 12mm (half inch) wider and left upper mount need to be modified.
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 15th March 2011, 01:24 PM
james3004's Avatar
I had the same problem, found it easier just to buy a 7 inch diff, you can't cut a lump off the diff as I tried it and the wall isn't thick enough.
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 15th March 2011, 01:25 PM
kinda worried about chopping into the diff is there going to be enough meat around about it ??
Old 15th March 2011, 01:38 PM
tex tex is offline
have you checked the diff ratios? i had a scorpio diff the big one and the ratios are not that good.. too long if i remember right [you can tell by taking the cover off its painted on the crown wheel edge]
Old 15th March 2011, 02:15 PM
After a quick google and removing the tag from the diff its a 3.91:1 ratio...please tell me this will be ok....???
Old 15th March 2011, 02:32 PM
loony's Avatar
You have to modify chassis/diff mount plate - not diff itself.
I don't think that chopping diff is a good idea
3.91 it's quite short ratio... it depends what you expect, but top speed will suffer...
I think standard Sierra diff is 3,62:1 ratio and is more suitable for lightweight roadster.
Lucas
My build thread
Old 15th March 2011, 03:22 PM
Eternal Eternal is offline
I did this the other day on a 7.5" was not too much trouble.
Last post on this page http://www.haynes.co.uk/forums/showt...t=4468&page=13
and first post on this one http://www.haynes.co.uk/forums/showt...t=4468&page=14
If you get a 2nd bracket and weld it to the edge of the bracket so its flush then cut out the top of the original bracket. All you then need is a longer bolt m12x60 and a 28mm spacer.
Skyline Roadster
Old 15th March 2011, 03:41 PM
Thanks Guys...Eternal especially...i even commentet on your work and it didnt click....i have some steel plate left over so will hack out another bit for the mount...thanks again
Old 15th March 2011, 04:04 PM
I have some spare 25mm round ally bar if you want i can drill and make you a spacer. Just let me know how wide you want it and your address and i will make and send it off.
Skyline Roadster
