Old 17th March 2011, 10:08 PM
ruffiac1 ruffiac1 is offline
Smile steering column support
Please could anyone give me the measurments for the sierra steering column supports part No's cp15 as i don't have donner parts yet! I would like to complete the steering wheel support frame thanks
Old 17th March 2011, 10:59 PM
shh120m's Avatar
shh120m shh120m is offline
best thing to do is fit the frame, and when you get your column, bolt on the plates and offer the column up. Then tack the plates in, remove the column and then fully weld and theyll be in the right place.
Hope that helps.
nathan
Old 18th March 2011, 03:53 PM
Smile Re: steering column brackets
Thanks for that Nathan I will wait until I have my donor .
thanks
Carl
Old 18th March 2011, 07:48 PM
shh120m's Avatar
no problem.
I tried twice to do it without the column by taking measurements from another chassis but the slightest difference and it wont fit or the steering wheel will be off centre. if your not too far away you could come and take the steering frame support plates if you want as i no longer need them as iv fitted a mondeo column.
