Old 20th March 2011, 06:45 PM
Peter-C Peter-C is offline
Default Foglamp switch
Has anyone used the foglamp switch from the sierra ? If so how did you wire it up ? From what I can see , by using the connection from the column pin 56 you put a negative to the positive side of the LED in the switch, therefore it cannot work.
Hope that is clear.
Peter
Old 20th March 2011, 07:31 PM
Have a read through this previous post and you will seehow gus and I wired his fog light up using the standard sierra light switch.
http://www.haynes.co.uk/forums/showthread.php?t=4022
Hope that helps
Old 20th March 2011, 09:51 PM
Cheers Dave,
I'll give it a go tomorrow.
Peter
